Check engine light: code P0348, a little help...
So, I finally got the code being thrown on my AR. From what I can gather doing a little searching this is an electrical issue related to the camshaft position sensor? Anyway, if anyone on here knows how to fix this or otherwise get the check engine light to go away it would be most helpful. Cannot pass emissions with the idiot light on and have had it cleared a couple times only for it to come right back on within minutes of driving.
All suggestions appreciated.
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
Bookmark this.
Next. You have a code for the camshaft position sensor. You won't solve the problem without replacing the sensor.
Bookmark this.
Any timing work done on the allroad? sometimes it could indicate incorrect timing, though rare.
i still vote for the sensor. if you have a good indy mechanic, he can test the sensor before replacing it.
Got the timing belt done at 80K, I'm around 95K now. There is evidence that they did not replace the gaskets while in there but I can't remember and can't find invoice so... Talked to an indy guy tonight who is quoting around 4hrs time plus another $80 for the sensor. He was willing to work with me on the cost of the sensor as I saw $13 for it at Autozone. Anyway, sounds like he is basically going to take apart the engine to get to this thing. I will ask about checking it first...
I hear you. No, its not. Just smarting from the fact that I feel like I'm doing the timing belts all over again but this time its a sensor...
carl viking
40
07-12-2024 02:45 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
