Check engine light issue
Old 01-11-2017, 04:39 PM
zimmarachi's Avatar
Default Check engine light issue
Hello everyone,
I recently had a fault code that my MAF was giving out high signal, i changed the MAF new one hitachi Friday and I cleared the code, ran the scan again and tested the value they are good 4.96 -5.11 while idle. Saturday the check engine light came back on so I scanned it again and I got a whole set of different fault codes.
17965 - charge pressure control
P1557 35-00 Positive Deviation
17861 - Exhaust Gas Temp Sensor 1 (G235)
p1453 35-10 Open or Short to plus - intermittent
17545 - Fuel Trim Bank 1 (add)
p1137 35-10 System too rich - intermittent
17547 - Fuel trim bank 2(add)
p1139 35-00 system too rich
Can someone please tell what the best way to go about solving these? Any idea on what might have caused these too?
Thanks,
Kazim
Old 02-02-2017, 06:08 PM
transman's Avatar
If you are getting between 4.96-5.11 g/s at idle for a MAF reading then you have a problem... It should be hovering around 3 g/s.. Something is causing excessive engine vacuum and that usually means there is a restriction around the airbox... Make sure the plastic pieces that go from the airbox to the rad support are not bostructed with a mouse nest or something...
Old 02-02-2017, 07:01 PM
zimmarachi's Avatar
thanks i'll check it out this weekend and see what i find again thank you
Old 02-14-2017, 10:10 PM
zimmarachi's Avatar
i took the whole intake system out, from the plastic vent leading to the intake box, all clean, took out the air filter and its all good K&N then the vent connecting the MAF to the Y shaped pipes are clear. reading that i got from the MAF was 4.28 was the lowest it got. what else should i do to troubleshoot now
thanks
Markgcb1
03-26-2007 05:28 PM
quattro100
02-07-2007 09:02 PM
2000redS4
04-09-2003 02:58 PM
VonDon
12-15-2002 04:47 PM
Quick Reply: Check engine light issue
