"Chipping", gas mileage, and reliability
#11
Just so you've got a good engine without underlying issues, tuning is the best bang for the buck !
you will feel like you are driving a new car with the 20 to 30% increase in power...
Most of the tuners are good and are safe for what you want...
good luck and let the dollars and stats help you make your decision
Visit company websites for
Revo, https://products.revotechnik.com/pro...eSoftware.aspx
giac, http://www.giacusa.com/
apr, http://www.goapr.com/
etc.. to see what works best for you...
OH, in every case in my car history(5 or 6 tuned vehicles),
tuning has increased mpg...
not enough to PAY for the new found fun, but if driven the same 1-2 mpg is a normal increase...
it changes the tq curve, and coasting down a hill in neutral gives a ton of ectra mileage.
fyi, adaptation 60 in the cluster will allow you to change your maf from a hitcahi to a bosch by changing the value to 0 if your tuned for it.
the reason this car has issues getting 30mpg on average is all the self protection measures using ectra fuel to cool down the cats......
also driving habits and hardware play a large factor along with oil weight annd quality.
ps, i almost have to drive in drive not sport mode with the apr chip otherwise i get fault codes. but reprograming the cliuter changes the shift points of the tranny!
thats why you get better mileage.
#15
You should come up to Manchester and drive my Stage 1 O.ct chipped 6 speed. A very noticeable bump in power and tq over stock, no loss of driveability or gas mileage either. We average almost 22 mpg combined driving. Nice linear power increase thru-out the rev-range too, very esay to live with.
I've been chipped for over 110K miles/6+ years, the motor is no worse for wear at nearly 180K (5K oil changes)
I can get your car chipped for under 500$ up here at the indy up the road,while you wait. You'll love it.
#16
I must be wrong here - generally all cars will cut fuel to the injectors when the throttle is zero and rpm is above idle. Is it true that the allroad TIP doesn't follow this programming? Neutral in any car will require fuel to keep it at idle rpm. This would be the first car I've ever owned that didn't have decel fuel cut if that's the case. I'm still learning over at nefmoto ...
#17
#18
#20
My 6-speed tranny is fine at 180K...the original fluid is in there too! Absolutely no issues in 1st or 2nd gear. I will say that when its very cold and at start-up the fluid is cold and thick , so the tranny seems a bit tight going into 1...but most any manual tranny will feel that way after a cold spell. Fluid thins down after warm-up ( maybe a few minutes of driving)
You are most welcome to come up and drive my allroad. We can even go up to the shop 5 miles up the road and drive 2 other 6-speed allroads that are on the lot.
Weren't you supposed to call and swing thru for a scan back in Nov2011? Anyway, the invite is always open !
