Climate Control - fan speed
Does this happen to anyone else? When I disengage
the "auto" button for the climate control and
try to change the fan speeds manually, the fan
speed increases by itself. Thanks..
Re: Climate Control - fan speed
Yes, mine does that. I actually think of it as a feature, not a bug. I like to leave it in disengaged "AUTO" mode with the fan speed on its lowest setting because I like how it stays quiet in the cabin with the lowest fan speed. However, if I am getting into the car and it has been parked in the sun, it will select a higher fan speed for a while and eventually try and settle back to the fan setting (lowest) that I had chosen. I am happy that it works this way because it means I can intervene less. I think it is very intelligent.
