Clutch bleeding
Did anyone here bleed the clutch on the AR? If so did you tackle it from the top of engine bay or underneath the car. I found it almost impossible from the bottom...and it also seems too far to reach from the top.
I managed to bleed it from the bottom... I basically squeezed my arm between the transmission and the down pipe to get to the bleeding screw...If anyone else plans to do a brake fluid flush(on a manual transmission) and encounters difficulties I would be happy to help. Maybe even take pictures...
I have the car up on jack stands, have removed the plastic shield under the car, and the heat shield over the driver's side axle, but I don't see it.
-Dan
I'm pretty sure you can only get to it from beneath the car. It's pretty much centered, but the hose will come out of the firewall on the driver side and the bleeder screw should be that side too.
On Audis, it's best to have a pressure bleeder for both brakes and clutch hydraulics.
Ok so I have two pictures. To properly see the clutch bleeding screw you have to put a light under the car(with the plastic belly pan cover off). So the first picture even though is fuzzy has the light on top of the engine to see where the aprox. area of viewing would be. The actual bleeding screw would be by the red spot in the blurry pic. If you notice the second picture is actually shot from the same spot but with the light under the car and zoomed in a little...and this second picture has the bleeding screw by the same red spot.
Detonator
07-28-2008 11:09 AM
nobodeuno
13
11-29-2007 07:13 AM
GDA4
04-05-2004 09:50 AM
LosGatosS4
11-02-2001 09:12 AM
