Coil over people: Has anyone tried coding their ECU to an A6 instead of the ar?
Maybe be an easy fix to not have the ECU look for the suspension module.<ul><li><a href="https://forums.audiworld.com/allroad/msgs/246311.phtml">same thought</a></li></ul>
Yes, on an '03' BEL w/a VAG under coding...
(I vaguely remember on the VAG how to get there, but I verified the specific code this AM). With a VAG go to coding under suspension allroad w/ASR post switch stage low range manual transmission; coding is 07715 for an '03' allroad w/BEL engine. Code for an A6 2.7t manual trans. w/ESP BEL engine is 07712. Change the 5 to a 2.
Does anyone have a VAG they can look at to verify the steps to reach this five digit code?
TT
TT
So if you used the procedure from here, but instead coded your last number
from a 5 designated for allroad to a 2 designated for an a6 it "should" no longer look for the suspension module, and it can probably be unplugged so it is no longer trying to communicate with the ECU and instrument cluster.
It may not hurt to re-code the instrument cluster to an a6 as well...
Also remember to save your old coding values just in case you should want to or have to return the car to stock...<ul><li><a href="http://s4wiki.com/wiki/Engine_recode">engine recode</a></li></ul>
gboogie21
07-11-2018 05:08 AM
Audi A6 2.7t APB mt6 ECU 4B0907551AA
redbullgotwings
01-08-2016 04:40 PM
timoti26
03-24-2014 05:56 PM
captainbilly
04-01-2001 08:20 AM
