Confused on antenna masts. I've got the '03 antenna base with the...
<center><img src="http://pictureposter.audiworld.com/100996/img00002.1.jpg"></center><p>GPS "puck" at the base (like the one above - thanks to a previous AW post).
My antenna mast is missing part of the rubber around the bottom part,and I'd like to replace it - with a shorter mast if possible. Which masts fit?? I bought one thinking it was right, but it was the standard VW/Audi thread size, and I guess this one is bigger?
I've searched but can't seem to find a definitive answer.
Thanks!
Thanks!
different. You should really get a proper reading of threads using a gauge, and go from there.
I have an ECS Tuning stubby on my 01 and it fits fine(with the 6mm thead, also came with a 5mm adapter)
<img src="http://img113.imageshack.us/img113/1701/dsc07451vc5.jpg">
None of the cheaper alternatives will fit the bigger threads (believe me I tried). You will need to spend some time with the VW parts guy but it is worth the ~$40 savings.
