Cooling fan are always on
#12
#14
actually, it's the blue aux fan switch under the front of the engine. the green sensor in the back is the coolant temp sensor for the ECM and cluster. both fail regularly and both use the same o ring and clip. with any fan issues, I have been told to replace both first and then look elsewhere. if not the aux fan switch, check the fan control module. a faulty module will throw a code I am told. I have read many posts where a new blue aux fan switch was the cure.
#15
Thanks
Dean
lmariorod
10-26-2017 11:39 AM
iamdrewseph
10-01-2015 11:33 AM
Jiggie
09-30-2015 07:14 PM
