cutting out on left hand turns
I have an 03 Allroad 2.7t with 86k on it. On semi sharp left hand turns (turning left from a red light or just a slightly sharp left turns) it feels like the engine misfires or cuts out while accelerating. I can coast through the turns with no problems, but as soon as I go to accelerate it shutters,cuts out or loses power (hard to explain the feeling). It also has just started to do it on right turns but not as bad.
No abs or esp lights flash and I dont have a VAG to see if its throwing any codes.
Anyone have any ideas what it could be?
Try removing your ignition key from your key chain. The weight of the extra keys swinging below the steering column can cause this. Heavy key chains can wear out an ignition lock cylinder...
This is were I would start.
I hope someone has a better suggestion for a solution to this. My car does this too on left turns under acceleration. It's feels a lot like hitting the rev-limiter. BTW, I have one house key (about 10 grams) on my key ring; don't think that's it.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Just trying to rule out the easy things first. This is more common than you might think....
Is it any worse when the tank is almost empty as compared to full?
What does the tach do when it cuts out? Do the RPM's drop or stay the same?
It sounds like a fuel delivery issue to me. I say this because;
I experienced the same issue with my (sold) 96 Eagle talon turbo AWD on hard right turns - like hesitation, slight bucking, or mis fire. The AWD talon fuel tank is shaped like a saddle bag and has one fuel pump located on passenger side of the tank. I would notice (of course) more when the car was at or below half tank. Anyway what I did was ordered a dual walbro kit to fix the issue.
can you make it do this while parked,ie turn the wheel sharply and rev the engine,is it ok when setting off straight,if power good in a straight line,i doubt its fuel supply.is there any noise when this happens.have seen seized alternators cause power and no crank situations,is there a steering joint seizing,power steering pump failing,this would drag the engine down....could be a bad wire in the steering coloum,you need to scan for some codes to get any further I think.
In all honesty I havnt had the fuel tank filled up all the way. But I will have to try it out and see. It does sorta feel like I get no pedal response when it happens. We just got a bad snow storm last night, but when I leave later ill pay closer attention to the rpms and such. Dosnt happen when parked with wheels turned or taking off..only accelerating out of left turns..I can coast threw turns with little throttle with no problems, but I have to slow way down.
Will a shop charge me to scan it?
