Dead dash - Here are the VAG Codes - ideas?
My speedometer, tach, temp, fuel gauge and computer won't work (with the exception of the temp reading). I hooked it up to VAG and got these two error codes. Anyone have experience with this problem? Wondering if I need to send the cluster out for repair or there might be a localized failure that is documented.
Your thoughts would be appreciated! Thank you!
Address 16 -------------------------------------------------------
Controller: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
1 Fault Found:
00480 - Control Module in Instruments for Infotainment CAN (J285)
27-10 - Implausible Signal - Intermitten
Address 56 -------------------------------------------------------
Controller: 4B0 035 195 L
Component: symphony II NP2 0051
Coding: 00205
Shop #: WSC 06125
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Coding: 01002
Shop #: WSC 02325
1 Fault Found:
Coding: 00205
Shop #: WSC 06125
1 Fault Found:
Vtec_Killer
11
08-26-2003 08:50 AM
Imola Ghost
VAG-COM Discussion
07-12-2003 09:04 AM
