Dealer called.. All complaints tended to (Anchor Audi Lynbrook Long Island)
Oil stainin on left rear diff/axel SEALS REPLACED
Leak from cam shaft/chain seals passenger rear, driver's front. REPLACED SEALS
Suspension warning light on ckuster 4 x in two weeks while driving. CODES INDICATED ABS MODULE FAILERE...REPLACED
Vibration from Shift **** REPLACED SHIFTER
Steering movement on turns, Steering off center since Turbo replacement was done STEERING UP TO SPEC, NO COMPONETS FAULTY
Suspension, ESP, ABS Light all at once today ABS MODULE REPLACED
Leather on driver's seat bolsters becoming hard like cardboard. PHOTOS TAKEN FOR ZONE REP
Wipers FRONT/REAR ALL THREE REPLACE
Electrical Harness Recall DONE PREVIOUSLY (I wanted to be sure)
HVAC Squeacking fan a mid speed... not constant but intermitant. REMOVED LEAVES FROM BLOWER N/C
Top cup holder rapid out. REPLACED CUP HOLDER
AM Radio not tuning in correctly SECOND COMPLAINT orginal complaint when new, was told no replacments in the pipeline yet. REPLACED HEAD UNIT.
Not bad.. I'll bick it up in a few hours.
And to think.. I still have 1500 miles until 50K and my final service... that's about 12 days for me.. LOL
The tech attached the NEW head unit's SAFE CODE CARD to my keys. I thought I was going to have to ask for it.
I just noticed.. they didn't just put in a new shifter or tighten the ball.. the leather boot is new also. The car drove well and had the smell of new gaskets 'seating' on the valve covers.
<center><img src="http://pictureposter.audiworld.com/67914/img_0063.jpg"></center><p>1. Fix the right rear a-arm deflector, duct tape holding it now after an earlier dealer repair failed. /see picture, tape mod done in Target parking lot, Casper, WY on 12-26. Rubbing on 16' snow wheels.. Annoying...
2. Passenger door opening while driving up our less than perfect dirt road, possible latch or adjustment problem.??
3. Rear lighter socket plug fast out, spring gone, who knows..
4. Driver's window moving slowly, track needs cleaning.
5. Passenger door light switch not working, is that part of the latch??
6. Rear hatch light switch not working
7. Front axle boots cracked, not yet failed, can I get them replaced??
8. Just replaced all the wipers, so that's off the list.
9. no noticable oil or airbag leaks, yet.
Any other thoughts??
paulroad
NY / NJ / CT Discussion
01-30-2005 04:38 AM
