Dome lights on all the time and auto door locks/switch
having two issues here that may be related:
1. unless in the off position all three dome lights are all on all the time regardless of doors, three doors & trunk show on the center LCD as open correctly and they light up when opened. the passenger door however does not show on the LCD when it is open, and the lights on the door do not light up.
2. key less remote locks and unlocks doors correctly, however the button on drivers door doesn't seem to work, at all. the car is programmed to lock the doors once heading down the road, it makes the mechanical sound, but the levers do not go down and the doors do not lock.
wondering if this is all is something completely wonky as a result of a faulty door latch on passenger side. Or two separate issues, one iwth a door latch and one with central locking feature.
insight is greatly appreciated.
I'm having the same issue. Door locks work fine, but when I turn the key on the ignition, the door locks quit working and the interior lights turn on. Did you ever fix the problem?
In each door inside the locking mechanism has 3/4 small circuit breakers.Their function is to tell the locking system whether the door is open / closed / locked / unlocked. These circuit breakers break down and sometimes work and sometimes not. A known problem with this vehicle
Looked into the door/hatch open light and they all work. It's strange the doors will lock inserting the key in the ignition, but when I turn the key to on, they act up. Locks click and interior lights turn on.
cb323
Audi A3 / S3 / RS 3 MKII
12-14-2015 02:37 PM
huwla
04-23-2006 08:21 AM
huwla
01-14-2003 11:30 PM
