Door Mirror at reverse gear
I have an Allroad2001, and have been quite
satisfied with it+GIAC.
One of the feature, I like, is mirror inclination@of passengers side door mirror, when gear is positioned at reverse direction.
,But yesterday I noticed it doesn't move that way any more. I checked with manual, but can't find any SW to enable, or disable the feature.
Is it just a trouble, or have I overlooked the SW?
Thanx for advise,
and hope all of Audee have a wonderful year!
Thanx for advise,
Re: Door Mirror at reverse gear
Make sure the mirror adjustor **** is postitioned to the right side mirror adjustor spot. Leave it there and hit reverse - it should work. If the **** is in the middle position, the reverse mirror will not operate. That is how it works on my '02.
Re: You can also rotate the switch to the left to drop the drivers mirror.
Dear folks,
thank you for your reply.
Those are really good input.
I will try on the way back home tonight.
I had a problem where someone ran into my RH mirror, knocking it loose...
It wobbled back-and-forth. After repositioning it approximately where it should be and turning the mirror switch off and back on again with the ignition switch ON, it resumed proper function (fortunately).
Follow it
03-23-2006 04:25 AM
Ari_UK
02-10-2003 10:54 PM
