Which EGT Sensor is 1?
I just had my codes diagnosed at the dealership. They state that 'replace exhaust temp. sensor 1' . How do I figure out which side that is and color?
Also I may try opening it up and resoldering the contacts, if that fails I will order the new boards from the 'Polish Guy'
Well I found this thread. Looks like 1 is the easier access...
I was told the EGT sensor was all over the map as far as temperature readings.
https://www.audiworld.com/forums/s4-...howto-1531865/
Awesome! Nobody even helped you out by responding to your post!
I had to buy the EGT PCB Boards for my EGT Sensors... I first tried re-soldering the original contact points, but that didn't last long. I finally installed the new boards and soldered, and no more codes ever since! only costed around $80 too, but had to ship from a guy in Poland or something.
Sal R.
06-29-2006 07:49 AM
98Blue
07-23-2003 07:39 PM
