Electrical failure
Help! I had a failure of my headlights, low beam. Hi beams work, only if I hold the lever back, fog lights, turn signals and blower motor. The blower I believe to be the resistor. So far all I've done is check the fuses and common grounds...help!
In the 100/200/v8 cars, the unrelayed headlights would burn out the undersized wiring in the headlight switch. Maybe something like this happened? Or maybe a relay? Are there headlight relays on newer Audis?
mcote1230
03-01-2008 06:40 PM
gt4mx5
08-26-2007 03:24 PM
iwillrefuse
03-16-2006 05:31 AM
