Engine Block Plug...
As many of you may recall, several weeks ago I was battling a cam position fault. It turned out to be the timing was slightly off. Apparently an unknown object got between the belt and the rollers/sprockets damaging the belt and causing it to skip a tooth or more.
During the troubleshooting process, the dealer removed an engine block plug on the drivers side of the engine. I assume to check an timing alignment mark (~shrug~).
Does oil come out of this hole when the plug is removed?
I assume not since it's above the oil pan(s). Can anybody confirm?
I usually send oil samples to Blackstone, and want to be sure they did not drain/add any oil as this would skew the test results.
Thanks!
Gavin
Thanks!
Gavin
HdiaS4
11
07-10-2007 07:23 PM
slightly disgruntled
04-24-2007 07:29 PM
getaudimyway
18
05-09-2006 07:05 PM
