Engine Coolant Temp Sensor code P0118
I got a CEL the other day. Comes on most of the time and goes off every now and then.
The code reads:
16502 - Engine Coolant Temp. Sensor (G62):Signal too High
P0118 - 35 - 10---Intermittent
Does anyone know what's the problem? I'm assume it just a bad sensor and I should just repalce it?
The code reads:
I've replaced both coolant temp sensors... one behind the pass side head, and the other at the lower radiator hose, pass side, accessible from under the vehicle.
Hints to install - when you purchase the new sensor, make sure you get a new plastic clip and a new o ring, and make sure the old o ring comes out before installation.
Bob
Bob
Jniebles
A4 (B7 Platform) Discussion
11-01-2012 06:28 AM
Asgor
VAG-COM Discussion
03-20-2007 07:29 AM
rd350
05-07-2005 10:22 AM
absentme
10-10-2002 07:05 PM
