erorr codes
Hello everyone
I have an Allraod Year 2002. lately warning lamp K134 turned on and with it a warning lamp of the dinamic headlights range control. I get code 2233 (J667). And numbers 14155 - 60239 to. my question is: what is these two numbers and what they say? I would grateful to get a link with information
related to these five digits codes.
Thanks all.
Amiram.
Thanks all.
Amiram.
This will be very helpful to you:
http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
Specifically, your problem is here http://wiki.ross-tech.com/wiki/index.php/02233
Did you scan them yourself, or a shop did it for you?
Don't forget, the same problem usually has 2 different codes for it. Unfortunately, I don't recognize the ones you supplied.
I scan with a handheld scanner "super vag k+can".I solved the problem of the code . Interesting to me to know what these code numbers mean. Scanner showed that three fault codes. First was the 2233 the second was 39,683 and 14,155 third. They mean something.
Thanks
Thanks
Stupid CEL, these same codes keep coming back....time to fix the problem instead of clearing the cod
DM-S4
04-14-2006 02:05 PM
