ESP won't completely turn off?
Playing around in an icy parking lot this morning, I confirmed my suspicion the the ESP on my '01 ar doesn't completely disengage when you have it "turned off"; it just seems to raise the threshhold wheelspin at which the controls kick in.
Does anybody know if you can make the on/off switch completely shut it down? Is this a VAG-COM mod?
TIA.
TIA.
I have come across the same thing recently just finishing a trip from Portland to Montana and back. I did some playing around with the ESP off in Montana...e-brake turns around corners, powering through others, etc. and I noticed that quite frequently I could feel my brakes up front engaging the rotor thus slowing wheel spin.(almost like hte ABS was kicking in) Kinda ticked me off and I thought that something was wrong...so it sounds like the ESP is never competely turned off? Anyone? Or do I have a problem with my 02'?
push the button to turn off ESP, get on the gas and start a turn and would find and hear a metalic like grinding noise and vibration in the brake pedal like the ABS was activating...interesting.
Does the diff lock engagement sound similar to ABS (a stuttering/vibrating noise)? If so, that would explain it. Of course you don't want the diff lock turning off when the wheels are spinning - that's why one buys Quattro!
Presumably you only hear the rear (and front?) diff locks; the center Torsen diff should be silent, I think.
Orthorex - read your manual, it tells you to turn off ESP in certain conditions like deep snow or sand.
