a fer error codes
I just scanned the care (2001 Allroad) and got these codes:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
Can someone please assist on telling me which o2 sensor is which. I also need to know which sensor is which.
Thanks,
Joe
P1113 - 35-00 - -
Thanks,
Joe
Yes I did. And unfortunately, the returned almost immediately. Now, I've had a faulty coolant temp sensor that was swapped out today for a new one. Is there any corrolation between the two. And maybe readiness needs to be reset on it's own over time? Or is this just wishful thinking on my part.
Thanks,
Joe
Thanks,
Joe
Samm, check engine light was on. When it first came on due to the coolant temp sensor last week, I scanned and there was nothing there with regard to the EGT sensor. I replaced my coolant temp sensor today and VAG'd the car to clear the error for the CTS. This is when I noticed the error for the EGT. I cleared all codes, but they returned after a couple of minutes (not the CTS code-that is gone)
I have 85k on my 2001 Allroad so I can expect to replace the O2 sensors at this point. But I'm looking for more info on the EGT before I purchase them.
Thanks,
Joe
Thanks,
Joe
M22
01-24-2010 04:13 PM
Jmacs4.2
10-02-2003 01:44 PM
