Fresh Codes.. And I have a few...
I have to say the VAG is a wonderfull tool, now If I could translate all of this.
Friday, 02 December 2005, 04:55:43
VAG-COM Version: Release 504.1-D
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 08 15 16 17 35 36 37 45 55 56 76
Address 01: Engine
Controller: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0010
Coding: 07715
Shop #: WSC 13623
WA1YD64BX3N102932 AUZ7Z0C2399388
1 Fault Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 4Z7 907 389 A
Component: ABS/ESP allrad D56
Coding: 06495
Shop #: WSC 08166
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
Address 08: Auto HVAC
Controller: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 08166
2 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
No fault code found.
Address 17: Instruments
Controller: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D12
Coding: 06264
Shop #: WSC 08166
1 Fault Found:
Address 35: Centr. Locks
Controller: 4B0 962 258 M
Component: Central Lock/Alarm D37
Coding: 15981
Shop #: WSC 08166
1 Fault Found:
01369 - Alarm triggered by Hood Switch
35-00 - -
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Controller: 4B0 035 195 S
Component: symphony II NP2 0011
Coding: 00201
Shop #: WSC 00000
End +++++++++++
Its safe to assume that my occasional suspension lights again eminate from the ABS module.
The over pressure charge exceeded, it a very seldom WOT symptom in a 3-4 shift. I've pressure tested and nothing is leaking It may just be time for new 710N valves as this is what I'm using and they have about 50k miles on them. I stil don't want to put in the Forges again..bad Karma.
Interesting that a few faults all point to the ECM.. perhaps just a loose connection, but this may have something to do with the "Hiccup" I experienced yesterday. It was short enough that no specific code was given..I think.
Address 01: Engine
Coding: 07715
Shop #: WSC 13623
1 Fault Found:
Coding: 06495
Shop #: WSC 08166
1 Fault Found:
Coding: 00010
Shop #: WSC 08166
2 Faults Found:
Coding: 01002
Shop #: WSC 02325
Coding: 06264
Shop #: WSC 08166
1 Fault Found:
Coding: 15981
Shop #: WSC 08166
1 Fault Found:
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Coding: 00201
Shop #: WSC 00000
End +++++++++++
If it has been a long time or if you just got the VAG-COM and never did it yourself before these codes could have been stored for a long time and may not represent current problems. I know some people say you shouldn't just clear codes without IDing problems, but if I were you I would just keep a record (you already did with this post) and clear 'em all. Then drive around with VAG for a while and see what codes if any creep back. I'll bet in will narrow down considerably.
See the below post for the explanation.
I know the excessive boost code was from last week. I get it now and then. I also know the ABS nodue code was from my last Suspension CEL of two weeks ago. These are recurring themes that I know of.
What I'm finding interesting is the intermitant communication with the ECM.. as a recurring theme in a few areas. This alone explains the 'hiccup' of last evening.
But I'm planning a dealer visit. I will clear them this morning and give them the print out and scan again prior to my visit in a week or so.
I recently added the tire monitoring to my ProDiag, but looking at your scan results, there may be some that I'm missing...
"ECUs we should be polling?"
There is only one ECU in the car.
Perahpaps you are referring to what Modules or channels you should scan?
VAG-COM has an auto scan feature that automaticall scans the major components. You can then pick an choose other componets as well, like the auto suspension system.
4B,Audi A6 C5,
01,02,03,06,08,15,16,17,18,34,35,36,37,45,55,56,57 ,67,75,76,77
Not all of these are present in the AR, and some are model year dependent.
Becasue I have a 2001, I edited the line to only include:
1,2,3,6,8,16,17,45
These are: Engine, Auto Trans. ABS, Seat Mem, HVAC, Steering wheel, Instruments, Interior monitor
(Skipped #15 airbags just to be safe)
2002+ models have more addresses active. Ross-Tech has a good list here:<ul><li><a href="http://www.ross-tech.com/vag-com/cars/applications/100a6.html">App Chart including allroad (A6/C5)</a></li></ul>
1,2,3,6,8,16,17,45
"17963 - Charge Pressure: Maximum Limit Exceeded". It should be caused by the exhaust bypass valve can not be opened properly. The most possible reasons should be the N75, or the hoses connected to N75, or the bypass valve get stuck.
Just my opinion.
Just my opinion.
joeycuccaro
NY / NJ / CT Discussion
11-11-2008 08:43 AM
IanB
11-03-2006 04:58 AM
