Front Brake upgrade from HP2
#12
Location: 100 km from Canberra, New South Wales, Australia
And are the HP2 pads more expensive (there's more of 'em)?
#14
HP-2 pads are not as common because far fewer Audis came with them. But they are an excellent choice for this heavy car.
My A6 has them (since it's a 4.2), my Allroad doesn't.
#15
I'm going to change the pads and see if that produces an improvement. The ones I have don't seem to have any bite.
I agree - on the face of it, a 4-pad disc brake should be half way to having a Big Brake Kit. How come they went backwards with the later 2-pad brake?
#16
Don't be quick to dismiss standard brakes. They're much more than just adequate.
#17
The real deal is get stainless steel brake lines, the Front Brake Caliper Stiffening Bushing Kit ( 4 pad brake setup ) $95 from tyrolsport.com, Zimmerman rotors & Hawk HPS pads. Don't forget to flush your brake line with high performance brake fluid.
You will definitely feel the improvement in braking. I ran my ar stage1 with this setup at Pocono HPDE and had a blast. Was one of the slowest on the straights ( real heavy wagon ) but on their *** in the curves. No brake fade. The Hawk HPS do give off dust but not as much as OEM pads
#18
Super low dust, great feel/performance, no noises, low price. Great street pad IMO.
I wasn't impressed with any of the EBCs, even on the track (though it was an entirely different car than the allroad) I do run EBC greens on the 500E, they are just 'OK'. I won't buy them again.
Posi Centric Ceramics are pretty good too for the money, I run them on my RS6. But not quite as low dust as advertised.
#19
Can these calipers be used with the existing discs for starters, my brakes at the moment are ATE calipers, single pot with 320mm discs, eliminating the need for getting merc discs?
DoubleB
13
09-19-2003 09:51 AM
