Front door latch issue
It seems to be a common problem discussed on various forums, but I've yet to find a definitive solution to this. My driver's front door doesn't latch properly and the door remains ajar or pops unlatched more often than it closes. I've tried various sprays in the external latch mechanism (i.e. with the door card in place) but nothing has worked. Is it just a matter of replacing the latch mechanism at this point or can it be disassembled, cleaned and regreased?
As soon as the weather cooled a bit I was having the same issue. I really didn't want to disassemble the door and replace the latch. So... I got out my trusty little squirter full of magic solution and gave the mechanism a couple of healthy squirts and viola, the problem is solved.
Oh, you say you want to know what the magic solution is?
Well, OK. It's a 50/50 solution of ATF and acetone. It's the best penetrant ever, better than all that stuff like PB Blaster, etc. It has been proven in testing to be better than all commercial products. Since I started using it I have never gone back to anything else. It has worked every time for me. It even works on pinch bolts.
Try it out.
Try it out.
Thanks for the input Mike. I've tried my magic acetone+ATF mix which loosens everything... no luck. I then tried with $$$ Krown penetrant followed by their rust solution/lubricant. It helped for a day, but it is still not latching consistently. It wasn't latching well in the fall and the cold weather seems to have made things worse.
Does anyone know which fuse to pull to dissable the interior lights? If the car sits for more than a day or two in the cold with its door ajar, the battery drains.
Wow. I've never heard of this problem until....
This morning, first morning since I've owned mine that the ambient temps were below 32 deg F in the morning. Driver's door bounced and wouldn't latch.
So it sounds like the solution is to get at the mechanism with lubricant to loosen up the stickiness, is that the issue?
Or is it an out-of-adjustment or wear issue?
With the ATF+Acetone and Krown lube in their now, it is at least closing reliably if you are gentle about it. A firm swing of the door, i.e. without having your hand on the handle when closing, and it still unlatches. A new latch mechanism from my local indy parts shop is $250. Anyone know of any cheaper options?
This might sound futile, but I would suggest that you apply more ATF+Acetone. It took 2 applications on my car, once in early autumn when the problem first arose and a second application a month later when it got a lot colder and the problem came back. In both instances relief was not immediate. It was probably 24-48 hours later that the problem disappeared for good. It's only 11 degrees here this morning and the door works fine, and it's been a month since the problem exhibited itself.
Good luck.
Good luck.
Roque
29
03-04-2009 10:33 AM
meem
07-28-2008 10:36 AM
