g76 level sensor issue
according to vcds the headlight range module can read the sensor just fine.. however the ride height error light is on, and it's throwing the code that it can't read the level in the level control module...
i saw a post which read 'The level sensor features two different and separate output signals (angle signals). The four-level pneumatic suspension system uses the PWM signal and the headlight range control system utilizes the angle-proportional voltage.'
If the sensor was duff could it affect only one of the readings? Or am i chasing down a wiring fault?
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
mart_o_rama
03-24-2013 11:26 AM
1 Bad DJ
09-04-2008 12:55 PM
