Gas? Do you smell gas?
Inside the cabin, I get a gasoline smell after the car has been sitting and idling for a while. It goes away once you start to drive. Probably a small leak somewhere under the hood, maybe the injection system? I'm trying to arrange some garage time so I can try to track it down. Working on a car outside at -40: ain't nobody got time for that.
Has anyone ever experienced something similar?
Check around your injectors. I'm just putting mine back together as I had a strong smell of fuel in the cabin. I opened the hood and could see it vapourizing off the engine. I pulled the injectors out and took them in to have them serviced. The problem was a bad o ring.
W12 Aficionado
Under the hood take the engine cover to the left of the Y-pipe off and look at the rubber line that connects to the hard line on the passenger side fuel rail in the rear. The hose is about 14" long and runs to the fire wall. The connection should be wet at the connection to the hard line. It is the fuel feed line for the fuel rail. P/N for 2.7T is 4B0-201-541-C. Be sure to check when you smell fuel because gas evaporates very quickly.
If it is the issue be sure to depressurize the line by pulling the fuel pump fuse and starting the car until it stalls and won't restart. Be careful still, there might be some pressure yet.
Best to take care of this quickly. You can find the line for about $85 these days.
i've had this twice in 5 years on my S4 and i just replaced them again and the POS still leaks when its cold only on 2 of the injectors.. not sure why or if i need to wiggle and reset the fuel rail but i hate it.. when its warm its fine of course.
