GAS GAS GAS
If you can't afford premium gas, just wait until you get to your first timing belt change....an Audi is probably not the best choice for someone that's going to agonize over buying premium fuel. :-)
Cheers,
Cheers,
Kind of a comparion and I found that the MPG was better with higher octane than with lower. But it was in direct relation to the $$/mile. IE: 93 Octane was 8% more cost and I got 8% better MPG. So, I give my car the higher octane, because I feel the difference and the out of pocket is the same.
In Colorado, I was able to run on 87 (at 5300 ft) with no noticible reduction in timing advance. Gas milage did not suffer either. I imagine when intake temps get higher, I might get some detonation on 87. You can always try it and see if you feel any difference. But my opinion is, I wouldn't tow a boat up any hills with less than 91/93. If you put-put around town you could be okay.
you can burn crap and be OK. But add some boost and you really need higher octane. So if you want to drive like the car can be driven then I would use 92/93 or whatever is in your area.
HarnessedLunacy
03-10-2004 04:36 PM
SlimS4
08-15-2001 12:31 PM
Tigole Bitties
06-28-2001 07:48 PM
