Geiger counter noise remedy....is there one single solution? Or multiple causes and solutions??
Before I head off to the mech, just wondering if I can narrow it down , before he rips the dash apart and says 'dunno mate' can't find it!?
incredible, isn't it, that VAG can build so many cars in which parts that never fail on any other brand routinely enough die such that even a guy with all left thumbs like myself can diagnose the problem. Turn signal relays or stalk switches (the part in the steering column)failing on a Honda, or even a Chevy, with this regularity? IMHO, but for the relatively small volume of cars and lack of complaint by owners, these should a NHTSA recalls given the frequency and the adverse safety effect of having impaired turn signals.
replace it myself.I had the same symptoms as you describe. I thought I'd try the electric contact cleaner route on the stalk. It worked immediately (after it dried)and so far the clicking has not returned.
I used CRC contact cleaner/lubricant and just sprayed into the column on the switch with the power off and worked the switch in all directions. Repeated once and let it dry.
You will have to excuse my ignorance here, but you guys feel fairly certain that its a switch/relay issue ? Although the turning signal stalk operates fine/normal ? I've heard the clicking noise on other vehicles and yes it was a flasher relay issue, but this sounds different and strangely non electrical. I searched the archives here as suggested by flintA6 and discovered the geiger counter description which is spot on. But the remedy(something to do with clips not being covered in felt) did'nt convince me. Thanks for everyone input thou .
