Got a email from VW about putting Nitrogen in my tires?
Old 02-09-2007, 02:01 PM
  #11
Member
Ex-PzKW Cdr's Avatar
Default pressure fluctuates with nitrogen as well, just not as much. MAIN benefit from N2 use in tires
is due to gas being "dry",as it's processed and filter from the atmosphere. During this process water vapor is drawn out and the carcass of the tire lasts longer due to water not dry rotting the tire. Now for me no tire on this car has ever lasted long enough for this ever to become a consideration. It's a revenue stream. I fill my own tires with good 'ole "air". I could sell many things to my customers in the name of revenue, I decline to abdicate from my moral position. I guess that's why I don't own a boat, mansion, and a Ferrari like every one else.
Old 02-09-2007, 02:27 PM
  #12
Nappy's Avatar
Default If I recall my G-chem corrrectly, N is a slightly lighter molecule...
than O, it's also slightly larger. So you get slightly less overall weight and less pressure will leach out over time. Reactivities to heat and pressure are also different between the two but, I don't know what effect that has on tires (if any).
  #13
paulroad's Avatar
Oy!! ;-)
Old 02-09-2007, 03:34 PM
  #14
New Member
Loseph's Avatar
Default Sorry i should have posted this differntly i am not interested in doing it, i just wondered what it
was all about. I would never spend money to put air in my tire's unless it greatly increses my MPG. I just had never heard of nitrogen in tires before so i wondered if anyone had info on it. Also i wondered it the dealers claims were legit.
Old 02-09-2007, 03:35 PM
  #15
mustbeaudi's Avatar
Default Vey!!
Can we get an "iz" and a "mir"?
Old 02-09-2007, 03:37 PM
  #16
mustbeaudi's Avatar
Default They point out that larger means less leakage, so better pressure over time and better MPG
but I agree - air is free, so use it as you please. You can always let it back into the atmosphere when you finish with it!
Old 02-10-2007, 07:31 PM
  #17
Fairbanks99's Avatar
Default Sam's Club should be able to do this for less than $7.
It is popular here in Fairbanks, where we have a very wide temperature range, +95 in the summer, -60 in the winter. Tires lose a lot of pressure when it gets real cold. I am getting nitrogen put in mine this week.
Old 02-12-2007, 10:51 AM
  #18
Plasticar's Avatar
Default the SLIGHT advantages of nitrogen
From MY understanding, nitrogen fill is good for two things. You are correct in that "pure" nitrogen is dry, and it is the water vapor, not the O2 that caused greater fluctuation in the pressures from temperature. Secondly, supposedly the N2 migrates through the tire carcass more slowly than O2, thus requiring less frequent top-off.
I wager most of us here probably check our pressures once per month MINIMUM, and probably at least inspect more often than that, especially during drastically changing temperatures. In this case, just keeping your tires properly inflated and inspected should accomplish the same thing.
berlina
Audi 100 / A6 (C4 Platform)
9
06-29-2008 08:20 AM
HarnessedLunacy
18
06-23-2006 10:24 AM
grandpamike
Chicago Discussion
01-25-2006 07:27 AM
Leaser
9
04-28-2005 12:25 AM
Cleepa
13
06-06-2004 09:52 AM
Quick Reply: Got a email from VW about putting Nitrogen in my tires?
