Help - 2.7T MAF / Vacuum line? GAS smell issues
#11
Since it seems to be temp related, it probably is the injectors - I've seen this in years past on other VW/Audi/Porsche products.......
Those vent lines are on the top of the tank, I don't know if you can see them from below or if you have to drop the tank - if so, I wouldn't do it.....
#12
I own a 2004 allroad. There is a recall for your problems.
Check with your dealer. Also ck Voluntary Emissions Service Action 28F2/J1 Ignition Coil Inspection/Replacement.
The gas tank requires baffles to be installed.
#14
Perhaps the recall fix didn't "take". ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
In December, the headlight switch recall was done on my car. Ever since then, unless the <b>headlights</b> are on, I have the headlight leveling error warning displayed. The leveling function works perfectly; but I still get the warning. As soon as a couple of other items are cleared up, it will go back to the dealer to be sorted out.
Good luck.
Good luck.
#15
It's warm out now. I'm chaulking it up to the injector(s). Going on a 1050mile road trip this weekend, so we'll see if I get stranded anywhere.
WClark
9
05-01-2007 03:38 PM
ehsix-4point2
04-22-2006 05:19 AM
ShoppingKartRacer
Audi 100 / A6 (C4 Platform)
13
11-21-2002 06:26 AM
