Help! I need a 2001 suspension control module (I think)
Hi folks,
The back end of my 2001 audi allroad is sagging and the mechanic tells me I need a new suspension control module (part number 4Z7907553H). Apparently it looks like it will take 10 days to get the replacement part. Does anyone know how to get a hold of a used part? Can I just disconnect the module and will the suspension then go back to a normal level?
Thanks!
George
Thanks!
George
that someone could use as a core. A new one is $$$ (~600$). I was lucky and found one used. Allroads are rare in wrecking yards, but you can try that route. I found one for an -02 in CT at a yard for $85. Google CT auto salvage. A lot of them have online search functions. I was told an 01 is unique though b/c of the "manual" function. Not sure if one from a later one will work or not.
I guess my question is, do you have a suspension fault light on in the dash? Also, is your compressor running? If one is no, 2 is yes, then it's not the suspension module.
Thanks for your help!
The dash light is on, but I don't hear the compressor. The light next to the level one indicator is one and blinking. I think the system is trying to raise the car, but I don't hear the compressor.
Can I simply disconnect the module and will the car then go to some sort of default level?
Thanks!
Thanks!
the sensor. You might need rear bags too. Is it down on both sides or just one?
also, try editing the subject line to make the forum easier to read...
Did you try carson at riverside audi or genuineaudiparts.com Craig is no longer there as I understand but they still have great prices and great service. Good luck...I wouldn't move it with it like that any more than you have to as the ESP also doesn't work when the ECU is out of wack. Trust me I know due to a really bad drive in slick weather.
hello
I've got similar problem yesterday.
Dashboard light come on and tha whole suspension panel is flashing. Vag says 65535 - Control modul for suspension leveling - Error
I think modoul is toasted.
I'm gonna take the modul out 2moro and have look.
Compresor dosn't work any more too...
fault in the memory and it's kaput. I have my old one in my garage if someone wants it to send off as a reprogrammed spare. The compressor will not work if there's a fault in the box.
BTDT.
BTDT.
gonna fix that for me. Cost of 210 euro. Still much cheaper then new one over here ( half price)
edit:
Well, I've got my module back, and ... it's not working...
Still same problem....
There is clicking noise coming from modul. Did you have same noise?
Light on the dashboard it's on, and lights on the panel are flashing ( all of them, up, down, level) Comp. not working...
I think i need New Modul....
The man says to send it back too him he will fix it again, but i've no time...
edit:
TweakitV10
11
04-13-2017 09:09 AM
nfocuz
Audi allroad
02-27-2008 05:15 AM
