Hi.. new to AR forum but not AW...have Washer Reservoir Leak question??
My washer reservoir or tubing has a leak somewhere as my low water icon popped up.
I would like to see where its coming from. Would I need to remove the well pan and check underneath there or from hood (top)? If you guys can tell me where the tubing runs, it'll help me a lot of time.
I am coming from an '03 B6 A4 Avant, now an '01 AllRoad.
Thanks!
Thanks!
number is 1T0955651A washer pump...they tested for power and ground at washer pump connector, maybe someone with a Bentley's can tell you where to test....I was quoted the part at $79.88 but that is retail, not sure what it would be otherwise. Good luck and welcome to ar forum I too have an '01.
when I ran the rear washer it would leak onto ground. they fixed under CPO warranty
assembly. First indication was washer fluid leaking into the rear hatch cover below the triangle storage.
The tech must not have tested it, because it still leaks!! It's the line to the rear, I think.
Now I have to go back to the dealer! :-(
Dville
9
04-05-2020 10:45 PM
Nogaro Stg3
06-01-2006 10:19 PM
RonDog
9
08-21-2002 10:18 AM
Quattro-X-2
08-29-2001 11:56 AM
