How do you over-ride the auto lock?
I did the auto lock at 15 mph / remote window mod and now everytime the AR exceed 15 mph I can hear the auto door locks kick in regardless if the doors are already locked. I may just disable this feature with the VAG if I can't figure what is tripping this.
So you get in the car, accelerate to 15mph, doors lock. If you drop below 15 mph (for a red light, etc.) the lock re-triggers when you acclerate over 15 mph?
Is this s tip or 6 sp? Mine will do same, but only if the car has been put in park and back into drive.
You are saying the doors UNLOCK when your speed dips below 15 MPH, and then relock when you go above?
If it is doing both of these, this is NOT normal behavior.
Or are you saying that EVERYTIME you go below 15 MPH and then above you hear it re-lock the doors?
It is supposed to just lock it once and that's it, not relock every time you go over 15 MPH.
Maybe the coding you used is incorrect, what value did you use?
I have mine set to 15981, give this value a try.
Other than this, it may be a bad "Central Lock" module.
Good luck!
Gavin
Good luck!
Gavin
Everytime the AR go below 15 MPH and then above, the doors would re-lock. Does not unlock then relock, but is locked and tries to lock again. I'm going to VAG it with the code again. It is currently set at 15977.
I have mine set to 15949.
Here is the link to all the window codes:<ul><li><a href="https://www.audiworld.com/tech/elec36.shtml">A6 Window Codes</a></li></ul>
Maini
VAG-COM Discussion
07-13-2008 12:29 PM
trojansruleucla
10-07-2002 10:45 AM
