Ignition switch and Door Locks/Interior Lights
Here's my problem and hopefully someone can help me. Door locks and unlocks with the key fob fine, the interior door lock switch works fine, the interior lights work fine on and off with the delay.
Now when I put the key into the ignition and put it in ACC and I lock the car with the interior lock switch, the locks click, stop working altogether and the interior light stays on. I then have to remove the key from the ignition and lock and unlock on the key fob for the locks and lights to work. So locking the car while in motion is not working at the moment.
I have checked the module under the carpet and it is not wet. Have checked all connections on door jams. Have removed fuse 14 and the locks do work with key ignition but then the power windows don't operate.
Is there a relay that I need to change?
2003 Allroad 2.7T
2003 Allroad 2.7T
A few years ago I replaced the flasher switch cause my blinkers were not working. I think after that my issues started. Your thoughts if it could be the switch.
krolls
Audi 100 / A6 (C4 Platform)
06-29-2008 05:39 PM
marklee
11-19-2006 11:29 PM
Sometimes alarm doesn't lock when I lock the doors and lights inside the car doesn't shut off (more)
turbovet
01-28-2000 10:39 AM
