I'm hearing LOTS squeaking noise from my suspension after 402 mod.(lvl 2)
I lowered 15F12R for the first time then 15F10R then put it back to original. Then I lowered 10mm on both f&r but it looked like front was lowered more so I raised 5mm only on fronts. Now that front is lowered 5mm and rear's lowered 10mm, it still looks like front is lowered more. It seems like undoing the 402 mod doesnt work on my ar???????
(I've read the direction millions of times before I did the 402 mod.)
I know I'd have to measure the actual distance from the center of the wheel to the top of fender's arch. But I'm not sure which arch I need to use.
re-tightened in level 2 with the car on the ground or a alignment rack. The shock lower mount bolt & sway bar end links should also be loosened & re-tightened . This will re-center the bushings. Hopefully you have not ripped the centers out of them .
joe@vwvortex
58
07-23-2008 02:33 PM
Greyhound Guy
05-05-2003 11:44 AM
