Just finished a Valve Cover Gasket replace and then this....
Hey Guys, I just finished a valve cover gasket and a timing chain tensioner gasket replace and know it seems as if I have an exhaust leak somewhere in the area. Just louder than normal.
I had to loosen up the egr valve feeder tube in order for me to slip off the valve cover. I'm guessing its here where the leak is but I can't tell for sure. I've tightened everything down pretty well. In fact I wouldn't want to torque it down any further.
Anybody ever encounter this and have any good leads for me?
Yep, had this happen to me too when I changed the pass side VC gaskets. I pulled the combi valve from the head to make sure it was clean, and when I pulled the second bolt the gasket fell into the abyss. I used a gasket from the driver's side valve because it has a third bolt hole in which you can bolt it to the back of the head and then install the valve without worrying about dropping the gasket again.
90sportin
Audi Original "S" Cars
9
04-09-2005 07:43 AM
Avants
11-15-2004 01:58 PM
Skywalker
07-08-2000 07:20 PM
