JUST FIX MY AIR SUSPENSION LEAK For 12$
#42
I found my leaks at the fittings - how to correct this- already tried new o-rings - still leaks. - Fitting on shock body and fitting coming out of yellow bottom of air spring - this is the rear.... 2002 Allroad
#44
Each connector has 2 O-rings. One, small, internal where the air hose enters Gently you can remove it if Require Clean or replace. And the second O-ring is the external. Check out the fitting thread in the air spring it must be clean
blazej01
15
01-22-2022 03:42 PM
