Kufatec Bluetooth
All- Have 2005 allroad with RNS-E and Dice unit for iPod integration. Would like to add OEM Bluetooth and was planning on using NSXJR but he is no longer supplying units. Saw that Kufatec has a retrofit kit, has anyone used it? If so, what is your experience? Plan on connecting to my Blackberry Bold or getting an iPhone. Any advise would be appreciated. TeddyBGame, are you lurking out there? What would you do? Thanks in advance. Thom
I installed the Kufatec unit about 3 months ago along with RSN-E, I love it crystal clear voice and I mounted the MIC in the overhead light - no problems at all ! You have control of the phone from the steering wheel but it only scrolls thru menus on the drivers display NOT on the RNS-E .....that just stays on the phone screen. You can also control your Ipod/Iphone and listen to songs it is however MONO and sound quality is not so good - I dont mind it as I will usually listed to pod cast or audio books thru blue tooth not my songs - for that I just use the SD slots in the RNS-E . I love the kufatec, You will need to VAG-COM the car to tell it you have the blue tooth unit.
regards,
Denni
regards,
Denni
allroadCole
Telematics Discussion
07-01-2007 08:23 AM
Max_A6
04-22-2005 05:36 AM
RageRacer
10-22-2002 01:56 PM
