Level Control System Sensor; Front Left (G78) - fault
My 2001 allroad with 115,000 miles is now throwing the following error code:
00776 - Level Control System Sensor; Front Left (G78):
Open or Short to Ground
No problem with air spring levels, no settling or drooping overnight, or anywhere or any other time.
Ride height automatic changes with speed function normally -- just drove 600 miles up and down I95 without incident.
Suspension compressor was replaced by the dealer a few weeks ago -- even before the replacement, never had an obvious issue with air spring level (just compressor noise).
Is this just a sensor issue, requiring simple replacement? Anyone know how much they cost, and if they are available outside of a dealer? Any place on the internet sell them?
Clearly, at 115,000 miles I am due for a leaking air bag -- could this code be sue to a leaking bag even though it is not evident?
With no obvious symptoms from the fault (other than the dash light & warning) is there a problem driving the car with it like this? The last 600 mile trip was fine. But I have to go on a 1800 mile round trip in a few days. Should I expect a problem, if I can't get a new sensor before I go?
Finally, what is involved in replacing the Level Control System Sensor; Front Left? Difficult or quick and simple?
Thanks.
Thanks.
I have the same year allroad and just had the same exact problem. I had a leaking airbag in my case it was the front right. I replaced the airbag and cleared the code and was good to go. Also you might want to take a look at the sensor itself. Alot of times they wire will stretch or brake from normal driving, or the plug will just become unseated, also causing your problem. Very good possibility that could be the case. I would check the sensor wiring and plug first being it could be the cheapest fix. hope this helps.
cory
cory
I'm dealing with the same issue. It actually has nothing to do with your suspension. The sensor measures where your suspension is, so it can adjust your headlights accordingly. Audi did this when they started using Xenon lenses so you won't blind other drivers when you hit little bumps in the road.
The Level Control System Uses two sensors, Front Left Sensor and Rear Left sensor to examine the status of the car to leveler. All four height sensors in the car are the same, only the arm and the base different. ( the system does not use this option at the right height sensors) You can replace with the Front right sensor. But before that check the Electrical connection of the sensor. And clean them
Start work only when that vehicle in "jack mode "
So I did a oil change on my car, had to lift it, and did not know about "jack mode" or "service mode".
Everything worked fine until that day, then the suspension dash light comes on. Now the front is down all the way but rear is still up in level 2 position.
The compressor is making noise.
What can be going on?
Any chance someone can show me where these sensors are at and how to clean them? I am having the following issue
In this case, maybe you need to clear the fault codes from the height control computer and not the height sensors
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
N'Syncro
33
02-16-2020 03:12 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
