Level sensor ?
Getting the Level susp. and Headlight adjustment warning.
Vag. Says: under Xenon block
00776 - Level Control System Sensor; Left Front (G78)
31-00 - Open or Short to Ground
Also says under Level control block
57-00 - Electric Circuit Failure
01771 - Control Module for Headlight Range (J431)
So I am new to the Vag-Com.
Is it that obvious that the level ctl for the front left is bad? Or could it be related to the headlight adjuster? Just trying to not order parts that I do not need.
Thanks for any input!
Don't know if this helps
Under level ctlr, Grp 4, all 4 levels are displayed (lvl ctl sensors)
Grp 5, Susp unit extention, front 1 has no number the other 3 have numbers
The headlight warning is tired in, but probably it is more level sensor related. Check the plug and its wires befor you order parts.
VAG is only a guide, regular search and rescue is always needed.
They replaced one of my height sensors as I had both lights on as well. No problems with the car height susp during the 3 weeks it took to get an appointment. (ar is under CPO)
I will take a look when I get home tonight. My susp ran fine when the sensor was bad so I guess it would be the headlight. But you could also argue that the car has a default mode so you can still drive it without any issues. Could it just read from the other good sensors??? Just a thought.
