A little DIY shift knob repair. A possible solution for those broken tabs....
Started with a an old **** (thanks Ali) that I recovered with some ultrasuede. **** didnt have the normal 4 tabs at the bottom that allow you to use a clamp to secure it to the shaft, so when I found it today, I looked at it and said there has to be an easy fix for this. Went to the garage and started digging around. Cut the tip off of a tube of silicone...too thick. Then BOOM...the sharpie (I like pen tube fixes as I used one a while ago to fix my visor clip ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Took some measurements and broke out the dremel and plastic weld and went to town:
Stared with:
![Name: IMAG1722.jpg
Size: 551.1 KB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84609d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag1722.jpg)
Supplies:
![Name: IMAG0556-1.jpg
Size: 1.06 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84610d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0556-1.jpg)
![Name: IMAG0561-1.jpg
Size: 1.52 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84611d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0561-1.jpg)
Used the dremel to thin out the inner walls of the cap to get the diameter as large as possible without breaking through the walls. Here is what I was left with:
![Name: IMAG0560-1.jpg
Size: 1.20 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84612d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0560-1.jpg)
![Name: IMAG0562-1.jpg
Size: 1.46 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84613d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0562-1.jpg)
![Name: IMAG0563-1.jpg
Size: 1.22 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84614d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0563-1.jpg)
![Name: IMAG0564-1.jpg
Size: 1.40 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84615d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0564-1.jpg)
![Name: IMAG0565-1.jpg
Size: 1.57 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84616d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0565-1.jpg)
A little Krylon Fusion matte black touch up paint with a brush on the glue and all done.
![Name: IMAG0571-1.jpg
Size: 1.30 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84617d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0571-1.jpg)
![Name: IMAG0573.jpg
Size: 1.32 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84618d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0573.jpg)
![Name: IMAG0577-1.jpg
Size: 1.35 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84619d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0577-1.jpg)
And the cool part...is the tip still caps off your sharpie:
Stared with:
Supplies:
![Name: IMAG0558-1.jpg
Size: 1.46 MB](https://www.audiworld.com/forums/attachments/audi-allroad-18/84620d1501531836-little-diy-shift-knob-repair-possible-solution-those-broken-tabs-imag0558-1.jpg)
LoPan455
A4 (B7 Platform) Discussion
12
08-21-2019 07:48 AM
LittleDevil
04-22-2016 11:10 AM
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
danfil
09-19-2015 06:32 PM
