Looking to put 19"s on the AR. What tire size and offset should I shoot for?
I am also have the 402 mod down 20mm/17mm, at least while parked.
Any suggestions? Any pics?
Call them and they'll go with you over the entire application.
But if you are willing to spend about $650 per wheel then go to www.der-abt.de
These are the Abt SP1 wheels on my car, 19" 255-45.
Good luck!
Good luck!
I think he had some 19" RS4 replicas that he wanted to sell. You'll need spacers for them to work on your car, but they would look nice.
as far as tire size, I'm not sure tirerack.com has a good +1 or +2 size calculator that should be able to help you.
with the offset that is more a function of rim width. if they are 8" wide rims you want to shoot for ET 25. 8.5 wide rims should be ET 20 if you find rims with a different offset you can use spacers to achieve the right offset.
OC02ALLROAD
Audi allroad
16
03-12-2007 05:58 PM
TTR-RIP
12-07-2004 05:21 PM
