low speed, full lock, dragging feeling? is it because its 4x4?
AudiWorld Uber User
Its because the torsen has no moving parts under normal traction conditions.
But in all of the torsen equipped Audis I've owned since I had an '88 90 quattro, the driveline makes the rumble when under power in a tight turn (making a u-turn, for instance). It won't make noise if coasting. I've found that unique to Audis - coincidently they were also all equipped with torsen center diffs.
If you trace the path the wheels make in a tight turn, the front-rear distance covered is very different. I *think* the noise you hear is the torsen distributing torque to wheels that have full traction.
I think this was explained in great technical depth waaay back on the audifans mailing list.
banal
10
10-14-2005 04:55 PM
Beng
07-08-2004 05:26 PM
A4_Jax
06-15-2004 01:13 PM
docjan_uk
04-25-2003 06:00 AM
