Manual tranny fluid info
Looked on this site for a "drivetrain" forum, but didn't find one.
I have an '02 AR with a 6-sp MT. The synchros are getting more and more rough, but I'm not replaceing it or re-building it until I see if a fluid change has any effect.
Does anyone know of any ADDITIVES to the Audi approved fluid that are safe, or have shown positive results, to use?
Fluid change won't help. It's a feature of this gearbox; at some point you will have to rebuild it with upgraded synchros. If they are getting rough, expect to be stranded without 1st and 2nd <b><i>soon</i></b>.
good luck
good luck
^^ This.
You could try running new fluid but unfortunately once your synchro's start to go there is not stopping it.
We have manual transmission fluid available below.
Click HERE to order or for more information.
![](http://www.ecstuning.com/groupheaders/img/TransmissionFluid.jpg)
Let me know if you have any questions.
Jason
Jason
I was just thinking there was something short of sawdust I could put in the tranny that might perform the same function...
Consider yourself (somewhat) lucky. I lost the clutch last spring and 3 weeks after getting the car back the first and second gear synchro's went. So I got to pay removal and reinstall labor twice.
Good luck.
It also could be your mounts from to much movement. Listen for a clunk between shifts not really loud but there. I'd start with a apikol diff mount plus cross bar bushings and start from there going to trans mounts and engine mounts.
gregg117
19
07-07-2020 02:40 PM
BAEL
Audi A3 / S3 / RS 3
10
02-15-2008 10:40 PM
FlyPenFly
A4 (B7 Platform) Discussion
9
11-01-2007 09:35 AM
PILL PUSHER
Audi allroad
11-26-2006 08:09 AM
BiturboBoy_V2.0_S3--
12-23-2004 04:00 PM
