MAX requested boost?
I'm getting a max requested boost of 1080 mbr(15.664psi) at 5680rpm, ran in third gear.Is this considered normal? The actual delivery is 1300 mbr(18.855psi) Although I haven't checked all hoses, the N75 valve has the proper resistance 30.9 ohms.
Of course I get 17965 fault.
Thanks for your thoughts on this
requested boost can't be 1080 mbar if you are giving throttle - thats basically what you should be at idle/off throttle/
in the 5K RPMs in 3rd if not chipped requested/actual boost should be b/n ~1600-1800 mbar
IF you are chipped - actual boost goes over 2000+ mbar
here is a conversion tool mbar into PSI --->>>>> http://www.sensorsone.co.uk/pressure...onversion.html
So whatever mbar you get minus 1000 (1000 mbar is atmospheric pressure)...
So 1800 mbar actual is 800 mbar boost = 11.6 PSI of boost
Hope that helps
Hope that helps
Hope that helps
Hope that helps
Hope that helps
Hope that helps
Thanks again
iamdrewseph
10-01-2015 11:33 AM
jamile222
09-29-2015 11:22 AM
