Mobil 1 Advanced Fuel Economy
Old 12-23-2010, 04:32 PM
  #21
swamper8's Avatar
Well for anyone else reading this thread and wondering, I went with a battery from Interstate. I went overkill and got the MTP-93. It has 850CCA and 1000CA. It fits perfect in the Allroad. It's about 2-3" longer than the MTP-91 (which I believe is closer to the stock battery) but the factory battery clamp can be used by moving it to the outer mounting hole. It spins over quite nicely now!
Old 12-26-2010, 06:46 PM
  #22
change2E85's Avatar
I just dropped in an Autozone special for $105. AZs are everywhere in Colorado so if it fails, getting a new one is just around the corner.
Old 12-29-2010, 02:38 PM
  #23
Mr. Timewise's Avatar
Originally Posted by swamper8
Anyone use 0W-40? Been googling the topic and it seems 0W-40 is high on people's list as well....
I just used Mobil 1 0W-40 which I purchased at AutoZone. Yes, it was $7.99 a quart. Ouch! The bottle does show the VW 502 approval.
I used 7 quarts and a Mann W 930/21 oil filter from Germanfilters dot com.
Link to Audi approved oils (a thread started in 2006):
http://forums.tdiclub.com/showthread.php?t=131951
Old 01-01-2011, 12:50 PM
  #24
swamper8's Avatar
Anyone else want to chime in on the quantity of oil they use for a oil change? I used the same Mann oil filter but only used between 6 and 6 1/2 quarts. I drove the car and then let it sit. Oil level reads right in the middle of the hatch marks on the dipstick.
Old 01-01-2011, 01:33 PM
  #25
I initially added about 6.5 quarts during my oil and filter change. The initial oil level was seen as near the bottom of the dip stick hash marks. At that point I added the rest of the 7th quart.
Then I ran the engine for 10 minutes or so to warm up the oil before making a "true" oil level measurement. After the engine was off, I let the car sit for a minute or two before checking the dip stick. This more or less duplicates what happens when stopping for fuel and then checking the oil level. The 7 quarts I put in the 2.7T brought the oil level to the top of the dip stick hash marks. Well, maybe a millimeter above the hash marks.
Prior to installing the oil filter I poured some oil into its center. This was to saturate the filter material with oil. When looking into the filter I would say I filled it about halfway. Only a very small amount (10 drops?) of this oil spilled out as the filter was quickly screwed in place.
Old 01-01-2011, 02:21 PM
  #26
5v/cyl's Avatar
Mine took 7 quarts using the Mann filter. Level when warm and after sitting a bit is at the top of the hash marks.
supawyde
08-30-2010 10:06 AM
DarkDays
15
05-01-2007 09:47 PM
huwla
23
10-06-2003 01:50 PM
AEGA4
07-07-2003 01:33 PM
ccooper
Audi allroad
12
05-06-2003 09:23 AM
Quick Reply: Mobil 1 Advanced Fuel Economy
