My Monthly Error codes.... comments welcome.
Old 08-25-2005, 07:25 AM
uber_ar's Avatar
Default My Monthly Error codes.... comments welcome.
VAG-COM Version: Release 504.1-D
Chassis Type: 4B - Audi Allroad C5
Scan: 01 02 03 08 15 16 17 34 35 36 37 45 55 56 76
Address 01: Engine
Controller: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 26131
WA1YD64B32N143739 AUZ7Z0B2113165
1 Fault Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 4Z7 927 156 F
Component: AG5 01V 2.7l5VT USA 1818
Coding: 00032
Shop #: WSC 00666
1 Fault Found:
17125 - Torque Converter Clutch: Stuck OFF / No Power being transferred
P0741 - 35-00 - -
Address 03: ABS Brakes
Controller: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06497
Shop #: WSC 26131
1 Fault Found:
01542 - Yaw Rate Sensor (G202)
27-00 - Implausible Signal
Address 34: Level Control
Controller: 4Z7 907 553 EĆ©
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 26131
3 Faults Found:
01577 - Turn-Off due to Over-Temp
35-10 - - - Intermittent
01772 - Signal from Level Control Pressure Sensor (G291)
01316 - ABS Control Module
79-00 - Please Check Fault Codes
End --------------------------------------------------------------------------------------------------
Old 08-25-2005, 07:47 AM
Senior Member
Rally_nutcase_1982's Avatar
Default That doesn't sound too healthy, don't have the Bentley here, but will follow up tonight.
Just curious, did hit anything on the road?
Old 08-25-2005, 08:00 AM
Member
Ex-PzKW Cdr's Avatar
Default Ignore implausable's for now, usually just a glitch.
Sounds like your torque converter crapped out, semi common problem, Take in for warranty.
Old 08-25-2005, 09:31 AM
uber_ar's Avatar
Default Re: Ignore implausable's for now, usually just a glitch.
No Warranty - 60k
TqConverter code is intermittant and we are discussing in a thread below... seems a few others are having the issue.
The level control thing has been happenning for a while - no effect on operation but the code come back every day.
The Yaw rate thing has been happening since day one the ESP kicks on at weird times in the twisty's.
Old 08-25-2005, 09:33 AM
uber_ar's Avatar
Default No impacts. Car in very good shape and well cared for.
See my response above.
My Bently is off line so I cant look up the yaw rate thing... I would like to replace the bad sensors in the ABS and Level control... if I knew which ones.
Old 08-25-2005, 09:44 AM
Member
Default No warranty? ouch. Needs a converter. Implausables could be a bad height sensor
Had one go bad and threw all kinds of codes. Could also be a wheel sensor. Front height and wheel sensors seem to be a modestly common problem
Old 08-25-2005, 10:43 AM
paulroad's Avatar
Default Uber.. at 60K...there is a good chance AoA will help out..
You need to call Customer service at AoA.. and politly explain what is happening and you love and history with the brand.
AoA may do 100% the may do 75% they may do 50-50. But... from what we have seen on the boards.. the will do something.. if you ask as its out of a dealer's hands.
Old 08-25-2005, 11:15 AM
uber_ar's Avatar
Default Well I'm going to have the dealer officially VAG it and then we will see.
The converter locks just fine as it has always done but ocassionallyt this error happens - does anyone know the duration of the failure required to show this error? 100ms 50ms ??? Just curious.
Old 08-25-2005, 01:22 PM
Senior Member
Default Geee....that is a lot of Information just from the Bentley, too much to post here.
But to get you started here are some copies of the Bentley output.
18032
Exhaust relevant malfunction from Transmission Control Module (TCM)
Note for malfunction P1624:
MIL stands for Malfunction Indicator Light. Once the Engine Control Module (ECM) recognizes a malfunction that adversely affects the exhaust emissions it switches the MIL on.
The MIL is switched on only by the Engine Control Module (ECM), since the ECM has the only connection to the MIL..
Malfunctions that affect the exhaust emissions can also be recognized by the Transmission Control Module (TCM), These malfunction are also indicated by the MIL.
Once the TCM recognizes a malfunction that adversely affects the exhaust emissions it sends a message to the ECM, the ECM then switches the MIL on. Simultaneously, the malfunction P1624 stored in the ECM noting that the MIL is switched on due to a transmission problem and not because of a engine problem.
17125
ATF level not OK or incorrect torque converter installed
Pressure Control Valve -N218 mechanically faulty
Problems with ATF supply to Pressure Control Valve -N218
Torque converter pressure pressure valve faulty.
Torque converter clutch valve faulty.
01542
The input signals received by ABS control module (w/EDL) -J104- are processed by internal programs and tested for plausibility. The program used to test the signal from sender for rotation rate -G202- is based on the signals from steering angle sensor -G85- and sensor for transverse acceleration -G200-. If sender for rotation rate -G202- is suspected to be the cause of the malfunction, first check that steering angle sensor -G85- and sensor for transverse acceleration -G200- are working properly.
- With vehicle moving in straight-ahead direction (v < 20 km/h), check zero position of steering angle sensor -G85- by selecting Function 08 "Read Measuring Value Block", Page 01-189 , Display Group 5, Page 01-203 .
- Check sensor for transverse acceleration -G200- as described under Function 08 "Read Measuring Value Block", Page 01-189 , Display Group 5, Page 01-203 .
And this goes on for pages....you'll need a Bentley if you are out of warranty IMHO. It's worth it.
Old 08-25-2005, 04:49 PM
Member
Default You just reminded me, Stearing angle sensor is a goody.
Alignment or new tires or a big enough jolt to the front end knocks the stearing angle sensor off slightly and causes a bunch of codes as well, yaw control being one of them.
Quick Reply: My Monthly Error codes.... comments welcome.
