Need advise, pleae help.
#11
1 Post
I replaced the front shocks when I replaced the air springs. I probably didn't need to...in retrospect I could have saved $ and just waited until the original shocks got older. I changed air springs when one was leaking overnight. The original air springs had about 112K miles. You can change one front air spring at a time even when you install a non-OEM (i.e., Arnott) air spring. In the rear, changing to the Arnott air spring on one side requires that the other side be changed.
I'm still on the original rear air spring and shock at 129K miles.
Torque converter failures are more common on earlier models.
Change the Tip fluid when you get the car. Audi says it's lifetime fluid. Don't believe Audi. Read this DIY...
http://www.audiction.com/audi-mainte...-fluid-change/
#12
Agreed. Fronts are particularly easy...backs a little more difficult because of a tight fit when removing/installing the uncompressed shock/air spring combo. The good news is that the fronts are usually the ones which need replacing.
Agreed. I understand that by 2005 all the Tiptronics came with an improved rotary seal. The earlier seal was the cause of so many failures. My 2002 has its original torque convertor.
#13
1 Post
https://www.audiworld.com/forums/sho....php?t=2062267
In fact, I'm selling that specific RNS-E right now for $900 complete. It works perfect.
#14
Have anyone installed this unit on their AR?
http://www.zenec.com/en/products/ego/audi/ze-nc3141d/
#16
Hi Guys, just when I was about to make a decision I ran across a guy next town over that is selling his 2005 AR with 66k miles for cheap 9k. Exterior has minor scratches and one decent size ding. Interior looks unreal with no visible wear and every single thing is working perfectly. Engine sounds extra quite and smooth. Car drives excellent and shifts silky smooth. Air suspension works very good. Now the bad, I asked why is he selling below average? Guy tells me that the car had water damage and was salvage. That struck me odd because this car looks, drives and feel better than the three I have seem before this one. The guy said that the problem were the front drains that leaked water into the car which he has replaced and are working like they should. This one is so tempting, should I run away or investigate some more and do a more detailed inspection? Thank you all.
#18
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
#19
So I shouldn't get too hung up on the water situation on this car given that everything works right? My fear is that Audi is no stranger to electrical problems and adding water to the mix might bite me in the *** later. I do have a Vag and will be bringing it with me if I go back to look at it again. If I scan it and inspect everything very close and all checks out ok, are my chances on the somewhat safe side if the above conditions are met?
#20
Since the water has been drained, and if all the electronics work fine (scan particularly the Comfort module), there's no reason to believe they will stop working. Water either got in and damaged them or it didn't.
What has he replaced? I find it odd that front drain problem would cause the car to be salvaged, so check carefully.
