Need help with 17545, 17547
#11
I have seen a bunch of bad maf's this year, mostly Bosch due to age, BUT, I have seen a couple of Hitachis go.
#13
leak post-turbo and the boost pressure being OK, then the MAF should be higher than normal, and it will come with rich condition. If an air leak pre-turbo will make the MAF lower, and it will come with lean condition.
17545 and 17547 are rich condition at idle. I think skidmark's suggestion should be checked first.
#15
your problem is not while running down the road but at no load such ad idle, still could be MAF sensor.
#16
not much load. Wondering if the FPR is not holding or a very small vacuum leak. I'll make another run and check block 211 and pressure test the system. Thanks for the insights and analysis..
#18
to MAF value. Just cleaned the MAF with Carb Cleaner will make another run. So is the consensus a bad MAF if cleaning doesn't change things or should I still pressure test the system?
<img src="http://pictureposter.audiworld.com/80294/10-5-2007log-003-031-211.jpg">
