Need help with 17545, 17547
#32
Here is the log of 001, 002
Going to replace the MAF next week, everything else checks out unless you see something with this log.
<img src="http://pictureposter.audiworld.com/80294/10-6-2007log-001-002.jpg">
#35
i have the same problems too i was at work and after work i went out and pulled up the vagcom n was reading the meas blocks to see my fuel trims the stft was ok within range so i took some carb cleaner and sprayed the intake boot wher it meets the throttle body and the trims went all goofy try doing that see if it helps that was my diagnosis
#36
you guys are saying maf but his trims are long term not short term try spraying carb clean around the throttle body i had the same problem and when i did that my fuel trims went all good fixed the boot and it was ok
#37
rich is vacuum leak
I got that rich code on my TT (from ECM trying to correct a vacuum leak by adding fuel) and found these tiny splits on one of the 'hard' vacuum lines under the intake manifold after I had replaced a lot of the other rubber vacuum hoses with no success.
Crippled_S4
05-23-2006 01:15 PM
mmms4
01-13-2005 08:28 PM
