Need help with my air suspension (02 mod allroad 2,5tdi).
I have som issues with my allroad... today suddenly the car went down to level one and the warning light came on...
Tried an output test with vcds, but the onliest thing happend was that suspension fwd was lowered below level 1.
Have tride to manually fill and bleed springs with vcds but nothing happends...
Any ideas out there?
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 06357
Shop #: WSC 02325
VCID: 09018B6FF939B27A483EB39-515E
1 Fault Found:
01310 - Level Control System Control Module (J197)
49-10 - No Communications - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 00410
VCID: 48874FDBA2B30B7297B0CE5-515E
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
01400 - Suspension Level Control
11-10 - Control Limit Not Reached - Intermittent
Address 34: Level Control (4Z7 907 553 F)
11:28:47 Group 005: Suspension unit extension
53.0 Front1 no units
27.0 Front2 no units
117.0 Rear1 no units
116.0 Rear2 no units
11:28:47 Group 006
35.0°C Pump temp (5-95C)
6.51 bar Reservoir pressure (3.58-15.96 bar)
OFF Reservoir valve OFF=Closed
OFF Pump ON|OFF
11:28:47 Group 007: Shock valve status (ON=OPEN)
OFF Front valve1 ON|OFF
OFF Front valve2 ON|OFF
OFF Rear valve1 ON|OFF
OFF Rear valve2 ON|OFF
Thursday,06,September,2018,11:30:41:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
11:30:36 Group 005: Suspension unit extension
116.0 Rear1 no units
11:30:36 Group 006
34.0°C Pump temp (5-95C)
OFF Pump ON|OFF
11:30:36 Group 007: Shock valve status (ON=OPEN)
ON Front valve1 ON|OFF
ON Front valve2 ON|OFF
Thursday,06,September,2018,11:34:43:04550
www.Ross-Tech.com
11:34:42 Group 005: Suspension unit extension
146.0 Front1 no units
100.0 Front2 no units
130.0 Rear1 no units
113.0 Rear2 no units
11:34:42 Group 006
2.93 bar Reservoir pressure (3.58-15.96 bar)
OFF Pump ON|OFF
11:34:42 Group 007: Shock valve status (ON=OPEN)
ON Rear valve1 ON|OFF
ON Rear valve2 ON|OFF
Thursday,06,September,2018,12:24:06:04550
www.Ross-Tech.com
12:24:03 Group 006
31.0°C Pump temp (5-95C)
2.60 bar Reservoir pressure (3.58-15.96 bar)
OFF Pump ON|OFF
12:24:03 Group 005: Suspension unit extension
247.0 Front1 no units
53.0 Front2 no units
148.0 Rear1 no units
111.0 Rear2 no units
12:24:03 Group 007: Shock valve status (ON=OPEN)
Coding: 06357
Shop #: WSC 02325
1 Fault Found:
Coding: 25500
Shop #: WSC 00410
2 Faults Found:
11:28:47 Group 006
OFF Pump ON|OFF
www.Ross-Tech.com
11:30:36 Group 006
OFF Pump ON|OFF
www.Ross-Tech.com
11:34:42 Group 006
OFF Pump ON|OFF
www.Ross-Tech.com
12:24:03 Group 006
OFF Pump ON|OFF
Forgot this one also...
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00030
Shop #: WSC 02335
VCID: 041F9A5BDE1BEF123B48FA5-4B4C
1 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
28-00 - Short to Plus
Coding: 00030
Shop #: WSC 02335
1 Faults Found:
nfocuz
Audi allroad
02-27-2008 05:15 AM
AudiForYou's 2.7T
Audi allroad
02-20-2005 05:40 AM
